Kết quả 1 đến 4 của 4
    513minh89 Guest
    build setting apk lg x145 4.4.2 lỗi mong ae giúp đỡ
    Đang dịch TV ....
    I: Using Apktool 2.0.0-Beta9 on Settings
    I: Checking whether sources has changed...
    I: Smaling...
    I: Checking whether resources has changed...
    I: Building resources...
    C:\Users\Administrator\Desktop\CLUBGSM Ver 6.0Pro\CLUBGSM Ver 6.0Pro\Settings
    es\values\styles.xml:69: error: Error retrieving parent for item: No resource found that matches the given name '@android:style/PreferencePanel'.
    es\values\styles.xml:77: error: Error retrieving parent for item: No resource found that matches the given name '@android:style/PreferenceHeaderList'.
    es\values\styles.xml:88: error: Error retrieving parent for item: No resource found that matches the given name '@android:style/PreferenceFragmentList'.
    es\values\styles.xml:189: error: Error retrieving parent for item: No resource found that matches the given name '@android:style/TextAppearance.Holo.Widget.Switch'.
    es\values\styles.xml:205: error: Error: No resource found that matches the given name: attr 'androidreferencePanelStyle'.
    es\values\styles.xml:215: error: Error: No resource found that matches the given name: attr 'androidreferencePanelStyle'.
    es\values\styles.xml:222: error: Error retrieving parent for item: No resource found that matches the given name '@android:style/Theme.Holo.Dialog.Alert'.
    es\values\styles.xml:229: error: Error retrieving parent for item: No resource found that matches the given name '@android:style/Theme.Holo.Light.Dialog.Alert'.
    es\values\styles.xml:241: error: Error: No resource found that matches the given name: attr 'androidreferenceFragmentListStyle'.
    es\values\styles.xml:242: error: Error: No resource found that matches the given name: attr 'androidreferenceFragmentPaddingSide'.
    es\values\styles.xml:239: error: Error: No resource found that matches the given name: attr 'androidreferenceHeaderPanelStyle'.
    es\values\styles.xml:240: error: Error: No resource found that matches the given name: attr 'androidreferenceListStyle'.
    es\values\styles.xml:238: error: Error: No resource found that matches the given name: attr 'androidreferencePanelStyle'.
    Exception in thread "main" brut.androlib.AndrolibException: brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [C:\Users\ADMINI~1\AppData\Local\Temp\brut_util_Jar _126685192603236818.tmp, p, --forced-package-id, 127, --min-sdk-version, 19, --target-sdk-version, 19, --version-code, 19, --version-name, 4.4.2-1413999404, -F, C:\Users\ADMINI~1\AppData\Local\Temp\APKTOOL153254 9528449055053.tmp, -0, arsc, -I, C:\Users\Administrator\apktool\framework\1.apk, -S, C:\Users\Administrator\Desktop\CLUBGSM Ver 6.0Pro\CLUBGSM Ver 6.0Pro\Settings
    es, -M, C:\Users\Administrator\Desktop\CLUBGSM Ver 6.0Pro\CLUBGSM Ver 6.0Pro\Settings\AndroidManifest.xml]
    at brut.androlib.Androlib.buildResourcesFull(Androlib .java:435)
    at brut.androlib.Androlib.buildResources(Androlib.jav a:363)
    at brut.androlib.Androlib.build(Androlib.java:286)
    at brut.androlib.Androlib.build(Androlib.java:258)
    at brut.apktool.Main.cmdBuild(Main.java:236)
    at brut.apktool.Main.main(Main.java:88)
    Caused by: brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [C:\Users\ADMINI~1\AppData\Local\Temp\brut_util_Jar _126685192603236818.tmp, p, --forced-package-id, 127, --min-sdk-version, 19, --target-sdk-version, 19, --version-code, 19, --version-name, 4.4.2-1413999404, -F, C:\Users\ADMINI~1\AppData\Local\Temp\APKTOOL153254 9528449055053.tmp, -0, arsc, -I, C:\Users\Administrator\apktool\framework\1.apk, -S, C:\Users\Administrator\Desktop\CLUBGSM Ver 6.0Pro\CLUBGSM Ver 6.0Pro\Settings
    at brut.androlib.res.AndrolibResources.aaptPackage(An drolibResources.java:470)
    at brut.androlib.Androlib.buildResourcesFull(Androlib .java:416)
    ... 5 more
    Caused by: brut.common.BrutException: could not exec command: [C:\Users\ADMINI~1\AppData\Local\Temp\brut_util_Jar _126685192603236818.tmp, p, --forced-package-id, 127, --min-sdk-version, 19, --target-sdk-version, 19, --version-code, 19, --version-name, 4.4.2-1413999404, -F, C:\Users\ADMINI~1\AppData\Local\Temp\APKTOOL153254 9528449055053.tmp, -0, arsc, -I, C:\Users\Administrator\apktool\framework\1.apk, -S, C:\Users\Administrator\Desktop\CLUBGSM Ver 6.0Pro\CLUBGSM Ver 6.0Pro\Settings
    at brut.util.OS.exec(OS.java:89)
    at brut.androlib.res.AndrolibResources.aaptPackage(An drolibResources.java:464)
    ... 6 more
    mong ae giúp đỡ
    file setting của e nó đây ạ Bạn không thể xem nội dung này - Vui lòng đăng ký thành viên để được xem ! Cảm ơn.
    hoaian Guest
    mong ae giúp đỡ
    suemall Guest
    giống mình hôm qua, nạp vô treo logo luôn.
    thuctapseonx01 Guest
    Trích dẫn Gửi bởi phucvinh_mb
    A Vinh có hướng khắc phục không cho e xin hướng dẫn khắc phục với
