Kết quả 1 đến 6 của 6
Chủ đề: How to bypass iCloud Lock for iOS 7/8! Tethered Bypass!
    gamevui5k Guest
    This is a new method to bypass the iCloud lock. This method will allow you to create a home made server to bypass the iCloud lock on your iPhone, iPad, or iPod Touch.
    Please note, this is not a permanent solution, you will not have carrier service, push notifications, and this is a tethered bypass (meaning you will have to redo this process every time you reboot) But the device can be jailbroken which can lead to a permanent solution.
    *****Your device must be on the "Slide to unlock" style lockscreen and NOT Hello/Hola/Bonjour/etc.*****
    Looks like this
    Link tải:
    1. Bạn không thể xem nội dung này - Vui lòng đăng ký thành viên để được xem ! Cảm ơn.
    2. Bạn không thể xem nội dung này - Vui lòng đăng ký thành viên để được xem ! Cảm ơn.
    3. Bạn không thể xem nội dung này - Vui lòng đăng ký thành viên để được xem ! Cảm ơn.
    Hướng dẫn
    1. Install the programs above
    2. Download the barney file and create the following directory -
    C:/xampp/htdocs/deviceservices/buddy
    3. Place the barney file in the folder created
    4. Open Fiddler, and at the top press "Tools" and then "Fiddler Options"
    5. Make it look like
    6. Edit your hosts file by adding this line: 127.0.0.1 static.ips.apple.com
    7. Open XAMPP and Start Apache and then restart Fiddler
    8. Open cmd (as admin) and type "ipconfig"
    9. Look for the line that has your ipv4 address. looks like
    10. On your device, press the home button and tap "More WiFi Settings" after connecting to WiFi
    11. Scroll down to "HTTP Proxy" and tap "Manual"
    12. Server is the IP address from step 9 and port is 8888
    13. Tap "BACK" then "NEXT"
    14. Tap "Activation Help"
    Your Phone Will Then CRASH and Respring into the home screen, and you have
    OFFICIALLY BYPASSED THE iCLOUD LOCK.
    nguyenvanan91 Guest
    cái này hỗ trợ nhưng dòng máy nào nhỉ, không biết từ 4S trở lên có ùng đươc không, làm được cho mấy còn đang màn hình active thì ngon nhỉ
    nguyenbahoang1 Guest
    Chỉ pass by ở tình trạng này, còn ở tình trạng active nhạc tk là cũng thua
    tks Smode, đánh dấu sẽ có khi dùng tới :13.jpg:
    b2ltpt Guest
    Trích dẫn Gửi bởi phuccnc9
    Test thử xem nào. Cho nó hot.:14.jpg:
  5. #5
    mantrangchu Guest
    Đúng là cao thủ apple - Ra toàn giải pháp giật mình choáng váng !
  6. #6
    ngavp_face Guest
    cách này pass vô được màn hình chính ok, xài như cái ipod touch, ko cài app được, tắt máy là trở lại lost mode, cắm vào itunes có mạng là bị khóa lại đưa về active ngay và luôn.
